LC/MS Autotuning [August 4, 2004]
Posted: Sun Aug 29, 2004 6:20 pm
LC/MS Autotuning
By Peter on Wednesday, August 4, 2004 - 04:25 am:
Hello, friends
When performing Autotuning and Calibration on LC/MS (Surveyor MSQ), the peak for the lower m/z (171-175) looks fine, but for the medium (1070-1074) and higher m/z (1970-1974), the peaks look waivy and noisy (zigzag). I tried to solve the problem but to no avail. What are your suggestions?
Thank you
By jay on Friday, August 6, 2004 - 01:52 am:
I have seen almost same behaviour but it passes the tune& calibration. Even I could do my qulitative analysis. What I notice is that about MSQ it needs to keepin vaccum for atleast 14hrs to get better response,If vaccum is down for maintenance.
By peter on Friday, August 6, 2004 - 04:21 am:
Hi, jay
Thank you for your reply. It does pass autotune and calibration. I can also do qualitative analysis, but i thought that may be there is a way of getting rid of waivy noisy baseline. Thank you once more.
Hello, friends
Thank you
Hi, jay
