Pump pulses in baseline
Posted: Wed Apr 12, 2006 2:04 pm
Hello
I'm having trouble resolving an issue with an ossicilating baseline that seems clearly to originate from the pump. When I double the flow rate the humps double in frequency, and they decrease in size by maybe a third. The noise is about 15mV and some of my smaller peaks are 150-200mV high.
The system has a crude pulse dampner, using a massive amount of side tubing to absorb the pulses, and I'm thinking of getting a off-the-shelf dampner to supplement/replace the manufacturer's.
Is my theory correct? Any ideas to flatten this down?
