Removing ferrules
Posted: Tue Nov 29, 2016 12:36 am
by jkloepping
What is the best method for removing vespel/graphite ferrules from the column nuts? The soft graphite are easy. but sometimes the harder ferrules are really difficult to remove. I've resorted to using an appropriately sized drillbit (the end without the cutting flutes) to force the ferrule out, but surely there is a better way?
Re: Removing ferrules
Posted: Tue Nov 29, 2016 6:21 am
by Peter Apps
If there is a better way I am yet to find it. Like you I use a flat-ended piece of steel rod, held in a pin vice, to shove the ferrule out.
Posted: Tue Nov 29, 2016 6:52 am
by tkubowicz
Hello
I'm using dentist tools made from stainless V6. They are really sharp and tough and they can do the trick.
Regards
Tomasz Kubowicz
Posted: Tue Nov 29, 2016 6:18 pm
by MSCHemist
I had the smallest size precission flathead screw driver that fits through the hole on the nut. I put it on the hole, tap with a hammer and the ferrule usually pops out in one piece. On my 5890-FID I use the same graphite vespel ferrules in reverse (pointy end towards detector) and special column nut (similar to the inlet nut but with greater depth) getting the ferrules of of them is a real nightmare.
Posted: Thu Dec 01, 2016 4:27 pm
by James_Ball
To remove the ferrule from the column nut that goes on the MS interface of the Agilent MS, I use a pushpin like is used on a bulletin board. I break off the column and insert the pushpin into the hole and push or tap until the ferrule pops out. For the inlet end I normally use my pocket knife blade.
Posted: Wed Dec 07, 2016 8:52 pm
by zegockie
A straight piece of a paper clip with gentle hammering will do the trick - I did this many times.
Posted: Thu Dec 08, 2016 12:57 am
by jkloepping
Thanks for the responses. I decided to buy a little pin vice from Amazon : https://www.amazon.com/gp/product/B0002 ... UTF8&psc=1
It comes with drill bits that and also nice little pointy tool that works pretty good for ejecting ferrules. I also ordered some sub-mm tungsten carbide rods from eBay and the combination should be perfect.
Posted: Sat Dec 17, 2016 5:34 pm
by Amirav
We at Aviv Analytical found a simple yet "magical" way to remove ferrules from nuts. Cut the column as short as conveniently possible around the column ferrule holding nut. Place the nut in a GC oven at 310ºC for a one-few minutes, cool down the GC oven to 40ºC and take the nut. The ferrule should now be lose and easy to remove. The reason behind this "trick" is that in unclamped nuts the ferrule expands to the open ferrule center and upward during heating and thus contract during cooling from the walls of the nut and become lose.
