Lab Contamination
Posted: Wed Apr 05, 2006 1:08 pm
I've recently had two instances of a laboratory contamination I'm trying to track down. I have been doing some trace analysis, concentrating down solvent extracts using high purity nitrogen. Once using hexane and a second time using acetone I have found a silicone oil (PDMS) in my extracts and blanks.
Since it occurred using two different solvents, I suspect it may be in my sample concentration step. I am using compressed Ultra High Purity (UHP) grade nitrogen for my blowdown. I have heard that it is possible to pick up contamination from compressed gas sources either when taking the tank down to near empty, or that there can be some bleed from components of the regulator.
Does anybody have any ideas, experienced any similar problems?
Mike
Mike
