I've created some custom fields in Empower according to our methods.
Response factor: RF_base = Area/(Potency_base*(Amount/Flask_volume))
Average RF (label ST only): AVE_RF_base = ST.%..AVE(RF_base)
Assay: ASSAY_base = Area/((SampleWeight/Flask_volume)*AVE_RF_base)
Everything works fine when I process a Sample Set. However if I manually integrate a peak in a sample in the Result Set, the results of the custom fields won't update after pressing the Quantitate button.
I hope it is possible without processing the Result Set with the "Quantitate Only" option, because this would give a whole bunch of unused Result Sets in Empower.
Does anyone know how this can be done?
Thanks in advance!
