% Area reports in Cerity sequences
Posted: Mon Apr 03, 2006 7:31 pm
The earlier thread is locked, sorry for revisiting the topic.
I've tried to follow Tim's suggestion ( in my version, 2.02, there's no "main peak" option under Quantitation ), and the report still comes out with all the signals. If I have the DAD acquiring at 205 and 220nm, I get signal 1 and signal 2 in the report table, each adding up to 100%.
That's using a report table format from the Quantitation selection of Peaks/Peak#, Signal/Sig#, Peaks/RT, Peaks/Peak Height, peaks/Peak Area, Peaks/Peak Width, Peaks/Area % relative to peaks on signal.
If I choose the Signals option under Quantitation instead of peaks, there is no Peak #, but making the same choices as I did under Peaks, then I end up with the table containing eack peak's result repeated in rows that match the total number of peaks integrated ( 5 integrated peaks would yield 5 x 5 line = 25 lines of table, 10 would yield 100 lines ). Oops.
The only way I've found to eliminate the second signal is to only record one DAD wavelength, or to reprocess with the integration of the second signal off - I'm sure I'm missing something obvious, but the local Agilent support person couldn't show me how to select and report just one of the DAD signals recorded, without going through nauseous calibration routines. For method development, I'd just like a simple Chemstation-like template that gave just a selected signal report as area %.
Any help is appreciated, and I'll try to respond in a more timely manner,
Bruce Hamilton
Bruce Hamilton
