Need Help with Agilent MassHunter Qualitative Analysis
Posted: Wed Nov 16, 2016 2:09 am
Hi all,
I'm a student working on an LC-MS project and am having great difficulty with Agilent MassHunter Qualitative Analysis. More specifically, I am trying to find an slick way to export my values of interest to an .csv or Excel format.
One way that I've had success with so far is by generating a "Integration Peak List" and exporting that. However, for some reason, the Integration Peak List is lacking in mass spec information, and instead only gives me information about my chromatagram peaks. It's a great start, but I really would like some m/z information to go along with it.
There is a column in the Integration Peak List called "base peak." According to the help documentation, this should be giving me "the m/z of the highest abundance point in the mass spectrum that was acquired closest to the retention time of the peak." This sounds like EXACTLY what I need, but the column is blank? Any ideas on why that might be?
Thanks in advance for any advice!
