Do I cool inlet and interface overnight?
Posted: Fri Mar 31, 2006 10:51 pm
by zimanli
Greetings,
I am new in GC/MS. I would like to ask a roobie question:
What temperature and pressure shall I set for oven, inlet, and interface for overnight? What shall I pay attention to when I go home?
Posted: Mon Apr 03, 2006 9:58 am
by Rafael Chust
For overnight purposes, I only reduce the flow rate and keep everything as settled for analysis.
In this way, I save time for next morning, avoid any sort of condensation and keep "cleaning" the system...
So what about the oven temperature? 50 or 100 C?
Posted: Mon Apr 03, 2006 2:27 pm
by zimanli
Thank you so much for your reply. I usually set my oven temperature 35 C, inlet 250, interface 250 etc. but I notice that the system is really dirty each morning I come in. Shall I inclease the oven temperature for overnight?
Posted: Mon Apr 03, 2006 2:32 pm
by Rafael Chust
I would do so with overnight temp being the first temp of program.
Anyway, you might need further cleaning, if your samples are dirty!
Posted: Tue Apr 04, 2006 2:21 am
by KC
I agree with Rafael. I would not turn temps down. Probably would not even reduce flows but thats not a bad idea.
Posted: Tue Apr 04, 2006 8:16 am
by Rafael Chust
Flow reduction is something I have always in mind because of cost and logistics of gases here in Portugal.
Gas generators are a rarity - I know one single company that use it! - and the local suppliers of special gases are rare and expensive!
If gas consumption is not a major concern, I would do as KC and keep the flow rate at analysis level - even overnight.
Repeating a very funny although clever phrase written in this forum: never trouble troubles until troubles trouble you!
Posted: Tue Apr 04, 2006 1:55 pm
by zimanli
never trouble troubles until troubles trouble you! It is a good one. Thanks
:D
