Front Inlet Pressure GC7890A
Posted: Mon Nov 14, 2016 1:20 am
Hi Everyone,
using GC7890A, suddenly front inlet pressure been increased to 134.5psi from set point pressure 13psi. Do not know what happened. Even tried to remove the gas supply, but still same 134.5psi. it supposed to read zero after disconnecting gas supply.
IF SOMEONE can advise what to do on it.
