loss of vacuum mid-run
Posted: Wed Nov 09, 2016 6:54 pm
Hi everyone -
I've been having an interesting problem. Around 13 minutes into my run (when the GC temp is at 94C), the roughage pump makes a weird gargling sound for about 3 seconds, and I lose vacuum (foreline pressure shoots up) and I get a massive peak. Even when I don't turn on the mass spec until after that peak, the roughage pump still makes that weird noise and I lose vacuum for about 10 seconds. None of that happens when I run a blank tube or a standard run. The worst part is that this happening at slightly different times every time I run a sample, so even if I turn the mass spec off up to 13 minutes, sometimes it happens at 13.5 or 14 minutes. Has anyone experienced this ? I am using a Thermo TRACE1300-ISQ system with a MARKES Unity 2 Thermal Desorber.
I talked to tech support and a few engineers and they have never heard of the problem. Could it be that the peak is so large that it is overloading the system to a degree that even the roughage pump can't handle it ? My sample is on thermal desorption tubes (so not liquid injection). Could there be moisture on the tube that is expanding when the column reaches a certain temperature ?
Loay
Loay
