Empower & Custom fields
Posted: Tue Mar 28, 2006 10:03 am
Hello !
I'm looking for someone who know the Empower custom field programmation language.
I would like to translate the match angle value (°) in match %. That's the reason why I create a custom field with the following formula :
100-(100xPDA Match angle/90)
The result is good but if no compound is found (PDA match angle is empty), the value is considered as equal to 0. So the Match % Calculated is equal to 100...
So how writing query in a custom field (if PDAmatch angle is not equal 0 then...)
I hope I would have been clear
