Chemstation printing / quantitating - Newbie problem
Posted: Tue Nov 01, 2016 8:34 pm
Hello
Apologies for posting a what might be a fairly obvious problem to some but we're currently having a few issues with our GC-MSs. I'm an analyst and have read through the manual but I wasn't around when our methods and macros were constructed and I'm a bit confused going in at the deep end!
My question is - Does chemstation automatically print out a basic report for every sample that is run? If so, how can we stop this occurring? Currently when we inject anything that is run as a 'blank' (assigned by 'type' on the sequence) we seem to get a very basic print out report of a chromatogram with the sample info at the top. This is in addition to our own custom analysis macros being run - which produce a completely different report. There is no identification of any peaks listed on the print out, just the chromatogram.
Our machines only appear to be doing this when the 'blank' is originally run. If I go to data analysis and re-run the method, it doesn't print out the report again which is confusing me slightly. Surely it should be doing the same thing each time it runs the method?
To our knowledge this hasn't always been the case so we must be able to stop it from doing it somehow!
Any thoughts or musings on our situation are welcome!
