Waters 2414, error message "LED intensity too low"
Posted: Mon Oct 31, 2016 3:28 pm
by srobertson
Keep getting this error message. Have purged for significant time.
Only running water through the system.
Any suggestions would be greatly appreciated.
Scott
Re: Waters 2414, error message "LED intensity too low"
Posted: Tue Nov 01, 2016 7:20 am
by tkubowicz
Hi
You should perform "Optimize LED" procedure.
Try to do below:
1.Press "DIAG"
2.Choose "Optimize LED"
Of course make sure you have cell properly flushed with water - you can try flush it backwards (just swap inlet with outlet)
Good luck
Regards
Tomasz Kubowicz
