SEC Columns HELP !!!
Posted: Tue Mar 21, 2006 1:28 pm
I am looking for SEC Columns (Aqueous & organic). Molecular weight of compounds in my analyte ranges from 200 to more than
2, 00,000. Can anyone help me out with following:
Which columns specifications can be suggested for this wide range of molecular weights?
What is the relation between Pore size and molecular weight for SEC?
Can the columns be used in series to separate this wide range of molecular weights? Please suggest the series.
Can I use mixed pore size column (extended bed or liner columns with varied pore sizes).
can you suggest appropriate guard columns also.
