Experience with XLB column
Posted: Fri Oct 14, 2016 10:16 am
I would like to know if anyone has experience with different manufacturers of XLB-columns. For the moment I'am using a XLB column from Phenomenex. Do you use Phenomenex, or Agilent, or Restek? Can you compare them? Have you had problems? Which one is the best?
Kind regards.
Kind regards.
