method of methscopolamine, phenylephrine & chlorphenaram
Posted: Fri Mar 17, 2006 4:26 am
Please help if you are interested in challenging separation.
1) all the following separation need to pass PDA purity test (wave length 200 to 300nm) and Rs >2.3;
2) separated the oxidation degradants from phenylephrine (20mg phenylephrine in 10 mL water containing 1 mL 3% H2O2 is heated over steam bath for 15 min to get the oxidation);
3) the same for CPM as 2) except for 30 min heating for CPM oxidation;
4) separate the impurity peak coming with sample diluent 0.2M KH2PO4 and showing up around CPM
5) the whole method run time < 30 min for separation of the all three actives in the title.
