test mixes
Posted: Sat Mar 11, 2006 12:19 am
by afischer
Has anyone run the following mixes on an Omegawax 320 capillary column. I am looking for the chromatographs of these runs with fatty acid labels on each of the peaks. Does anyone know where I might be able to obtain these? Thanks.
Supelco 47080-U Bacterial Acid Methyl Esters CP
Supelco 47085-U PUFA No. 3 from Menhaden Oil
Search Supelco web site
Posted: Tue Mar 14, 2006 1:07 pm
by chromatographer1
I hope this helps.
PUFA #!1 on the 30M x 0.32mm x 0.25umdf Omegawax.
Search for T799031.pdf
Posted: Tue Apr 04, 2006 11:13 pm
by afischer
that worked , thank you
