water problem with USP 467 residual solvents
Posted: Fri Sep 16, 2016 7:14 pm
HI everyone,
Our company just equipped a PerkinElmer GC together with H40 Head-space for USP 467 residual solvents analysis.
Now I am able to apply the USP method only when water is not added to headspace vial (according to USP 5ml of water is supposed to be used)
When water is not added (only residual solvent standards in DMSO) all peaks come out perfectly separated and peak shape everything is great.
However, if add the 1ml sample/standard into 5ml of water for analysis, peaks are co-eluting and peak shapes are awlfull, especially at the beginning half of the chromatogram.
I tried increase the needle temperature and transfer line temperature to 110C and 125C respectively, to eliminate the possibility of water condensation, however, the result is the same.
Dose anyone have the same experience?
