Prep-LC to Flash Chromatography Conversion?
Posted: Sat Sep 10, 2016 12:41 am
Hi everyone,
I'm looking at a paper (https://www.dropbox.com/s/zaap5o4vqcr7n ... 6.pdf?dl=0) that performed isolation of natural polymers (proanthocyanidins) based on their degree of polymerization using a diol preparative column with a 100um particle size. I don't have prep-LC experience, but I've been using a flash chromatography system to do fractionation of natural products. Does anyone with experience using these two systems think it's possible to use a diol flash cartridge with similar or smaller particle size to achieve a reasonably similar resolution as in this paper? I'm referring to the chromatogram in figure 5. The company I'm looking into (Interchim) is offering samples of these cartridges down to a particle size of 15um, but also has 30 and 50um. I'm not sure if there are any other factors coming into play that effects resolution between the preparative columns and flash cartridges.
Thanks in advance for any advice!
