non-injection method with Masshunter data acquisition
Posted: Fri Sep 09, 2016 6:47 pm
Hi All,
We are new to Masshunter data acquisition. We try to transfer Chemstation sequences (GC) to Masshunter. Two things we used to do with Chemstation sequence: 1) if we leave blank in the vial cell in the sequence table, there will be no injection at the beginning of the method run 2) if multiple runs for the method out of the same vial, we use >1 in the inj/vial cell and the method will run multiple times. We are trying to transfer these two functions into Masshunter data acquisition sequences. Called Agilent, no satisfied answer yet. Masshunter do not take blank or 0 for the vial cell. We do not want any injection step at the beginning of the method run. We also could not find inj/vial or similar in the sequence configuration for multiple runs. Any idea for solving these two issues? Thank you for any suggestion you might have.
Katherine
Katherine
