5971 broken quad support - what to do?
Posted: Thu Sep 08, 2016 11:28 pm
I've been having some problems with tuning on a 5971. Finally, having swapped all boards, electron multipliers, checked connections, reinstalled software, and many other things, I took the mass analyzer apart. I found that the ceramic quad support on the source side has a quite fragile "nose" that protrudes in to the mass analyzer. Two rather large broken pieces were floating around in the analyzer. I have a spare, so I replaced the part and I'll see over the next few days if that fixed the problem.
My question is, what is the purpose of the nose on the support, and what would be the harm if the nose was left broken? The purpose cannot be quad support, because that is provided by the outer ring of the insulator. I assume that it prevents ions from migrating to the outside of the quad?
