Controlling an external solenoid valve from on Agilent 6980N
Posted: Tue Feb 28, 2006 9:33 am
To automate a manual operation I need to open and close a solenoid valve at pre-set times during an analysis.
According to the instruction book (page 218) this shuld be possible using the programmable external valve control of the 6890N GC, but what is conspicuously absent from the instructions is the location of the connector to which the valve has to be connected.
What I need is the location of the controller outputs for external valves 1-4 which give 13 W at 24 V.
Agilent's only suggestion is that I buy something from them ! (is any Agilent owner surprised ?) which I do not want to do until I know that what I am trying to do with the valve actually solves the problem it is supposed to.
Does anyone know how to do this - preferably in terms of "the connector is at the top/bottom left/right of the board next to the gizmo and under the whatsit"
Thanks Peter
Thanks Peter
