terminology
Posted: Mon Feb 20, 2006 8:33 pm
hello
When i infuse a solution of water, acetonitrile or methanol into the MS there are usually no peaks on the scan spectrum however when i try to capture the ms scan sometimes there is one significant peak showing up however if i had waiting for 1 second then that peak would have gone. What is the name for this phenomenon whereby blips are seem momentarily on the spectrum. Unfortunately i have just noticed that all my spectra from solutions which should contain nothing have one small but noticeable sharp peak in them at random masses. I do not want to redo the infusions so if anyone knows the name of this phenomenon then i could use it to explain these random peaks
