Bits of septum stuck to insert assembly
Posted: Fri Feb 17, 2006 9:43 pm
Hi, this is probably a simple one, but could someone please help. I've got bits of septum stuck to my insert assembly (almost certainly due to overtightening). Is there a solvent that I could use to sweep away the bits of septum? (I'm using the GC with quite a sensitive mass spectrometer.)
