Agilent HPLC manual injector
Posted: Mon Aug 22, 2016 2:18 am
I have an Agilent 1100 HPLC and I've just bought a Rheodyne 8125 manual injector.
My problem is that I can't get it to send the start signal to the Chemstation software. I'm new to Chemstation, and I've been looking for a setting that tells it to look for a manual injection, but can't find anything.
I don't have the factory cable - instead I've made a cable up that hooks into the APG port with a BNC connection. The position sensor has been checked and is open circuit in "load" and closed in "inject", right up to the connector.
If someone can help, I would greatly appreciate it.
Is this a software setting problem, or a hardware problem?
