Cross coupling products separation
Posted: Fri Aug 19, 2016 6:51 pm
by antonis
Hallo,
I have access to an Agilent 7820A CG system with an HP-5 column and looking in aromatic cross coupling products and starting materials such as: benzyl bromide, 3 Methoxybenzyl bromide, bi-phenyl, bi-tolyl, bi-benzyl, 3 Methoxybenzyl tolyl, etc.
I would like to set a new method for separating those efficiently (quickly and with good resolution), hence wondering if anyone has any suggestions I can use as a starting point.
I cant change the instrument or column.
Thank you for your time.
