Syst Suit as Method User Program addon in Totalchrom
Posted: Tue Feb 14, 2006 10:39 pm
by Mary Carson
Has anyone out there done this? I'd like to automate the sys. suit. tests a bit more so that I can get tailing factors, etc., on regular reports and summaries. I apparently am not getting the syntax right on the command line. Manual is a little vague here.
Thought I remembered someone posting instructions to do this on this forum, but I couldn't find that post.
Posted: Wed Feb 15, 2006 9:29 am
by WK
Hi Mary,
I had to play around a bit! Select the suitability (suit.exe) program file in the first line of "User programs" tab (when in method>process>user programs.It should display the suit.exe file extension in the box next to the radio button.
I had:
$RSTspacee:\turbochrommethods\fingerprint.suispace/1spaceprn<epsonspacestylusspacecolorspace850>
I have typed space for one space between letters/numerals
where e:\turbochrommethods\fingerprint.sui was the file and epson stylus color 850 was my printer - you may have to use exact upper and lower case on the printer name.
I found the program didn't work unless I had the exact syntax - so keep trying and experiment.
Please post if it works or not
WK
Automating sys suit
Posted: Wed Feb 15, 2006 10:27 pm
by Mary Carson
Haven't found the right syntax to make it work yet. Fly in the ointment seems to be that we're actually running Totalchrom Small Client Server version--filenames with pathnames need to be in quotes (maybe), and using the right naming convention. PE tech support is helping with this. Maybe we'll have it figured out by tomorrow.
