Suppression of residual DMSO peak by API
Posted: Tue Feb 14, 2006 4:47 pm
I'm currently fine-tuning a headspace method for, among other things, residual DMSO. In the process of doing spike recovery with different APIs, I noticed something odd:
Depending on the exact sample, the slope of my calibration curve may be reduced by up to 20%, and this is consistent across the range of 500-5000 ppm. None of the other residual solvents in my standard exhibit this behavior (well, ok, DMF does, but to a lesser degree). The linearity is not a problem. This is very repeatable.
Has anyone else encountered this?
