I have an Agilent 7683 autosampler mounted on a 6850.
Sometimes, the autosampler miss a vial and then the sequence interrupts.
This is very problematic when I have a long sequence list.
I was wondering if there's a way or a command to tell the Chemstation (REV. Rev A.10.02) to continue the sequence even if a sample is missed by the autosampler.
Thank you in advance
