adapting assays in a new lab - revalidation?
Posted: Thu Feb 09, 2006 5:29 pm
I’m leaving next week for Mongolia to help train lab personnel there to use HPLC (as part of a development grant). I’ve used HPLC for some time as an academic pharmacologist, but admit I’m not as up to date as I should be with QA issues. I could use some advise on a few things.
The lab I'm going to is "starting from scratch" relative to HPLC. They have however picked methods to analyze certain drugs that I believe have been validated, if not by a pharmacopoeia then by a drug company.
My question is:
-Should this lab perform a method (re)validation on each assay, even though it's been validated elsewhere, or will periodic equipment qualification along with QC samples and daily system suitability tests be adequate? If the revalidation needs to be performed, should it be complete or only address certain parts? If the latter, which would you suggest?
My second question is related to the inclusion of Quality Control Samples. In a document from the FDA it says:
a) Do you think these recommendations are appropriate for a lab testing drug formulations rather than plasma samples? If not, what would you suggest?
b) Should blanks always be included?
c) Can these same samples be used to determine accuracy, bias, and precision?
Many thanks for taking the time to help me,
Cory
My question is:
I've used this approach for plasma samples.[use] at least 3 known concentrations of analyte freshly spiked in control matrix, one being at a point 2 standard deviations above the LOQ, one in the middle of the range of the standard curve ("mid-range") and one at a point 2 standard deviations below the upper quantitative limit of the standard curve. [with] 6 replicates of each concentration.
Cory
