How to get a LPGC (Low pressure Gas chromatography) System
Posted: Sun Aug 07, 2016 6:31 pm
Hi all.
I have a standar Single quad GCMS-QP and a Triple quad GCMS-TQ. I listened in a conference that is possible to adapt those systems to a LPGC(Low pressure gas chromatography) system, putting two columns in serie with different ID.
The column connected to the MS is usually a narrower one, and the other is at atmospheric pressure.
Is it true? does anyone of you ever try it?. I heard that improves the resolution of the peaks and get faster results.
Does anyone recommend any literature about this? or any technical information.
I´ll appreciate any comment.
