One of my clients has produced a validation protocol for an SEC column changeover.
In their proposed testing protocol they have stated that they wish to change the storage solution from the manufacturer’s recommendation (20% Ethanol) to our working buffer (a saline formulation buffer) with a little Sodium Azide.
Their justification is as follows:
- Reduced flushing times as we will no longer need to flush with water prior to or after storage solution.
- Longer column life as it will avoid contraction and expansion of the agarose gel beads caused by the change in solvents.
I was wondering if this is common practice? Has anybody had any experience with this and does it help?
