ELSD - inefficient nebulisation?
Posted: Thu Jul 21, 2016 8:26 am
We are having problems with ELSD signal response reproducibility - possibly caused by baseline noise. On reading a guide to ELSDs, it is my understanding that all solvent should be evaporated, and therefore the amount of waste solvent fairly minimal. We have noticed that the amount of waste solvent is approx. the same as the amount used to run the samples. Does this suggest inefficient nebulisation, and therefore a fault with the nebuliser? Or is it usual for most/all of the nebulised solvent to be recondensed? Any help would be much appreciated.
