Chemstation Self Created Library Read only
Posted: Tue Jul 12, 2016 8:38 pm
by pmiller
When trying to edit a self created library by adding a spectrum reference through Chemstation. An error shows up that says that library is read only. This only occurs when using Chemstation. We are using the BA version on Windows 2000. I am not an analyst. I am the systems engineer trying to help an analyst out. Please forgive me in advance if I don't immediately understand parts of the discussion. All help would be greatly appreciated. This worked up until recently.
Re: Chemstation Self Created Library Read only
Posted: Tue Jul 12, 2016 11:52 pm
by chemstation
what is meant by
only chemstation can read Chemstation .L libraries
unless you are writing about a user created NIST library.
If you want to convert a user created NIST library to chemstation .L library
try Lib2nist.exe
http://chemdata.nist.gov/mass-spc/ftp/d ... s/Lib2NIST
worse case scenario is to convert chemstation .L library to NIST and then back again if there is some sort of file access privilege issue.
Posted: Thu Jul 14, 2016 1:58 pm
by KM-USA
The Chemical structure and mass parts of the entry cannot be changed after entering, the other stuff can.
Can you create a new Directory (like ABC.L) and then copy the FILES from the existing library into that directory, and see if that works?
