It's not a bad idea to place a guard column before the injector. Actually, such columns are called saturator columns and they serve two purposes - protect the analytical column and protect injector seals.
Usually, silica saturator columns are installed between the pump and injector, to protect reverse phase columns from harsh mobile phase conditions - like extreme pH, high temperature and high buffer salt concentrations.
When used in conjunction with regular guard columns, saturator columns can dramatically increase column life and injector performance.
However, there is a price to pay - higher backpressure and consequent wear and tear on pump components and higher dead volume, that can affect gradient-based analyses.
