Solvents to be used when using Fluorescence detector in HPLC
Posted: Thu Jan 19, 2006 3:48 am
Hi!
I've been using HPLC for years but with UV detectors. I'm using a more sensititve Fluorescence right now and I noticed that even HPLC grade MeOH has peaks. I also tested deionized water and it also has peaks eluting in the chromatograms. Do i need to use distilled MeOH? We used distilled water and filtered it after putting activated charcoal but there are still unwanted peaks eluting. I wonder what solvent type do I need use? Any help? Thanks.
-ghie-
-ghie-
