Command to generate percent report
Posted: Sat Jul 02, 2016 5:40 pm
Currently creating a very basic macro to reduce some keystrokes in chemstation.
Here's what I have so far:
My normal routine would be to extract ions, integrate, then generate a percent report for peak height and corrected area for each m/z.
When I use the PCTRPTOPT with no parameters specified, it fails to generate a report.
I know that I'm extracting and integrating correctly because it shows up with my draw command... but I can't even manually generate a percent report after that. The report is empty.
Does anyone have any suggestions or advice?
Thanks!
Like I said. Very basic. I started reading up on macros yesterday.chromatogr 14.087:19.246,234,235,237,239
integrate
draw 2
Thanks!
