High frequency noise late in chromatograms
Posted: Tue Jan 17, 2006 4:50 pm
Hi All,
I am having recurring, intermittent, problems with high frequency noise showing up at later retention times (higher temps) in my chromatograms. I have also run through the temperature program without injecting a sample and I see the same behavior, so I don't believe it to be sample related. Could it be related to detector gas purity or transient leaks?
The time/temp at which the noise occurs varies a bit, but is always at least 5 minutes in.
Here are the conditions:
HP 5890GC
Rtx5 column (0.53mm, 0.3 um, 15m)
Injector 250C
FID at 350C
Ramp 25 C/min (start at 50C for 0.5 min)
Final temp 225C
Any thoughts on troubleshooting this vexing issue would be apprecaited.
Thanks.
HP 5890GC
Injector 250C
FID at 350C
Final temp 225C
Thanks.
