Suppressor Over-Voltage Error
Posted: Tue Jun 28, 2016 6:52 pm
Recently I have been trying to create standards with Ion Chromatography
(ICS-2000) for an project/experiment that I am doing.
Some background information: the previous users of this device did not prepare the suppressor and the machine for "hibernation" before stop using it, and the IC system had not been used for about a year. Thus, the machine was all dried out and our old suppressor was "shot". I have attempted to bring it "back from the dead" and I have successfully fixed most of the issues, including moistening the system, raising the pressure, etc... we needed to get a new suppressor, and so the model of the new suppressor is an ACRS-500 ICE.
Going back to the problem, when I tried to load the autosampler (AS40 autosampler) with liquid samples, it was interrupted and the IC-2000 kept having the error of "suppressor over voltage". Does anybody have any suggestions on how to fix this?
Also, what current (mA) should the suppressor/detector setting be set to? There is no ACRS option in the settings, so it was suggested to put it under MMS. However, I'm not sure what to do for the current. Furthermore, when I put it under MMS setting, the chromeleon software does not allow me to even turn on the suppressor.
Any suggestions will be appreciated. Thanks.
