Good resources for reading a tune report for MS?
Posted: Tue Jun 28, 2016 4:07 pm
Our lab primarily uses GC/MS, with Agilent 6890/7890 and 5973/5975 (and 5977 soon, if we can fix this damn air leak) mass specs. All EI. I have a fair amount of experience with these systems, but some of our newer analysts do not, and since my experience is mostly trial and error and anecdotal evidence, I'd like some resources on how to better read a tune and how errant results will manifest in sample runs.
This stems from a recent run in which an analyst cleaned the 5975 EI source, ran a tune (which passed the tune eval), and ran a sample batch which subsequently looked terrible (on a new column). I looked at the tune, the 219 and 502 were 220% and 45% respectively, with a horrendous ion focus ramp. To me, this just says the source is dirty and needs to be cleaned again, but I can't articulate as to why this is bad (since it did, technically, PASS).
I'd love some literature or references to materials on how to better read autotunes, lens ramp shape, etc and how errant results will effect samples. For example, if you ion lens looks bad, what is happening to your sample as it passes through. How/why does it effect it in this way?
Sorry if I'm not stating what I'm looking for very clearly.
