Waters 2695 pump lubrication
Posted: Tue Jun 28, 2016 8:30 am
Hi all, Could anyone tell me what type / grade of grease and oil you would use to lubricate the pumps on a Waters 2695 HPLC? I was having some synchronisation problems between the two pumps on my system so stripped the pumps down to check the bearings inside and need to replace some of the grease and oil that has been removed during the process. Our system has an older oil lubricated pump and a slightly newer grease lubricated pump - I'm not sure why it is fitted with two different pumps but this has worked well for a number of years. From what I've read I probably need a lithium grease and a light oil but further details would be useful. Realise this system is almost obsolete but your help and advice would be appreciated. Thanks in advance, Christine
