Resolution Calc in Data systems
Posted: Tue Jun 21, 2016 6:30 am
I have noticed in two different Chromatographic data systems that resolution is only calculated between the named analyte and the first peak to the left of that peak. In order to calculate resolution to the right, you either need to also name that peak or use a customized report. Any idea why certain data systems have this limitation?
http://mariaexarchakis.weebly.com/
http://exarchakis.com/
