Amino acid analysis by Dionex AAA direct method
Posted: Fri Jan 06, 2006 10:31 am
by stanlee
Has anyone run this method ?
Going to set up our system next week so wondered if there were any useful hints/tips I should know about.
TIA
Stanlee
Re: Amino acid analysis by Dionex AAA direct method
Posted: Fri Jan 06, 2006 11:29 am
by amaryl
TIA
Stanlee
Go to menu bar and click on search, type keywords 'amino acids'.
Hope it helps
Amaryl.
Posted: Fri Jan 06, 2006 1:05 pm
by SIELC_Tech
Hi Stanlee,
Did you have any luck with you previous approach- amino acids on Primesep columns?
http://www.sepsci.com/chromforum/viewto ... ed1f5#9664
I did not follow up with you on this. If you don't mind would you please update me (
vlad.orlovsky@sielc.com)
Thanks a lot,
Vlad
