Borate carry-over problem as hard nut to crack. Help needed!
Posted: Thu Dec 29, 2005 12:56 pm
Dear All,
I turn to you after trying almost everything to resolve this tricky carry-over problem (at least we think its carry-over). We are detecting borax with HPLC system having a RI detector. The standard solution prepared from boric acid dissolved in water is 0.25 mg/mL. System parameters are as follows:
Mobile phase: 0.25 mmol/L perchloric acid
Injection volume: 20 µL
Column: Shim-pack SCR-102H (8.0 mmI.D. x 300mm) Shimadzu Co.
Column oven and RI detector T: 40°C
Polarity /sens.: +32
First we used simply mobile phase as a needle-wash solution. Mobile phase is injected after six standard injections. The carry-over peak area varied between 1.2 - 5.4 % compared to standard peak area. The same phenomenon was noticed in Waters Alliance 2695 and Agilent 1100 systems. The reason for % carry-over variance remains unknown, even though it seems that carry-over is smaller, when mobile phase is injected before any standard injections after having washed the system throughly. Then different tests were carried out with Waters system:
1) needle wash solution 50%MeOH; carry-over 3.2%
2) needle wash solution 100%MeOH; carry-over 4.5%
3) needle wash solution mobile phase, but vials without septums and every mobile phase injection from separate vials; carry-over 3.4%
4) needle wash solution mobile phase, but no boric acid standard was introduced to system, only borax sample; carry-over 3.2%
5) when injection volume was doubled the carry-over peak area was doubled as well as standard; carry-over 4.1%
6) Standard and mobile phase were analyzed for 60 minutes and no peaks eluted after borate peak.
In every test the needlewash time was extended.
The system was washed with water and methanol, and passivated with 6N nitric acid. The purge injector, primeneedlewash were performed with all wash solutions and nitric acid. Tests were carried out after this.
7) needle wash solution water; carry-over 0.8%
8.) the test 7) was repeated; carry-over 1.7%
9) needle wash solution 6N nitric acid; carry-over 2%
And that's it. My mind is empty. Has anyone played around with this kind of phenomenon before? Any advices?
Best regards,
JAM
Best regards,
JAM
