From what I've read thus far, it's happening with all the peaks, RRT's are steady, temperature is controlled, sample is stable, column has been equilibrated before use and there are no leaks in the system.
Please check the flow rate accuracy. Depending on how old your pump is and depending on the drive system it uses, flow rates can vary over prolonged use. Cam-drive pumps can have fluctuations in flow rate, as they age. This is just a possibility! I don't know how old your pump is or if you regularly follow IQ/OQ/PQ procedures, but there's no harm in checking the flow rate anyway.
So I'd suggest you check the flow rate over the day. You may check with and without the column. It's easy to check and doesn't take much time.
If I'm wrong and your pump is OK, then breathe easy. It's the column most likely.
In which case, I'd suggest ( this is what I would do)
- Reverse the column. Disconnect from detector. Flush with mobile phase for about an hour ( to flush out the frit), reconnect detector, equilibrate system as usual, run your samples overnight.
The idea is to check what's happening, not to use your column long-term in the reverse position. Briefly reversing the column won't destroy it - in fact, it'll probably flush out the frit and reduce backpressure when you use the column in its normal mode.
If the same RT problem occurs, even on the reversed column, and if your pump is OK, then I must agree with Uwe - you need to take a hard look at the temperature control.
You can always check the temperature control by injecting a totally different sample on the same column. You can inject the test mixture that must have come with the column - or make one yourself.
You can also inject your sample of interest on a different C8 column or a C18 column, if you have one.
If RT's are changing as before, no matter which column or sample you run, then it is a temperature issue.
If it's happening only with one particular column and everything else is OK - pump, temperature, sample, mobile phase, etc.. then I'm afraid you have one very naughty C8 column.
Hope this helps. You can accept or reject all the above suggestions - but this what I would have done. There are no shortcuts I'm afraid.
Do let us know - one way or the other.
