NORMAL PHASE CHROMATOGRAPHY- MOBILE PHASE
Posted: Sun Dec 25, 2005 3:18 pm
Dear all,
Merry Christmas to all of you. I am a new member and I have a question for everyone.
I came across a method ( USP monograph -method) for estimation of Methylprednisolone in Methylprednisolone Sodium Succinate for Injection which uses following mobile phase.
Mobile phase:A filtered mixture of butyl Chloride , water- saturated butyl chloride, THF , methanol and glacial acetic acid ( 95:95:14:7:6).
Column : 300 x 4 mm,5µm -, Porous silica particles
I was wondering why water saturated butyl chloride and ordinary butyl chloride is used.
I looked for answers and asked many people . One of the answers I got is even in Normal phase chromatography there is a minimum amount of water is required to get proper resolution. Is it true? But Why??? Then why we spend so much time in taking change over from reverse phase to normal phase .( Purging the system with Methanol , IPA etc.)
One more interesting fact I tried to omit the water saturated part of mobile phase preparation. I was getting the almost same Retention time. Some one suggested to me that the acetic acid contains enough water in it to make the butyl chloride saturated. Is it true??
Thanks in advance for your answers.
