Carbon Surface Coverage
Posted: Thu Dec 22, 2005 9:58 pm
I am trying to compare between 6 columns all with C-18 solid phase. I got different resolution values for 3 PAH isomers. I noticed that the best resolution achieved by the columns with the highest carbon load and surface area but low pore sizes.
I read in this forum that carbon load only, is not the best way to compare between different C18 columns and it is better to use Carbon Surface Coverage. However, I could not find this value for most of the columns I used.
My Questions:
Is there any equation to calculate Carbon Surface Coverage based on the other column variables?
How can we relate resolution to the Carbon Surface Coverage?
Thank you in advance.
My Questions:
