Fluorescence detector settings [November 18, 2003]
Posted: Wed Aug 25, 2004 6:42 pm
by admin
By Anonymous on Tuesday, November 18, 2003 - 10:39 am:
when you want to implement a method using fluorescence detector, is there any problem in using the maximum gain possible? (18)has this any effect on the detector, the lamp, the memory used, etc,anyway, is this more desirable than injecting more volume into the column, I guess, if I need a very low detection limit (0.01ppb)
By Anonymous on Tuesday, November 18, 2003 - 01:19 pm:
Gain increases both signal and noise, injecting a larger volume increases signal. Sensitivity is signal/noise.
