These reference related to stability of cefuroxime may be useful:
1. Cefuroxime hydrolysis kinetics and stability predictions in aqueous solution. J Pharm Sci. 1994 Apr;83(4):577-81.
Below is some text from this reference in PUBMED:
A. Acetate, phosphate, and borate buffers did not catalyze degradation.
B. Maximum stability was observed in the pH-independent region from pH 4 to 7, where the time during which cefuroxime concentration exceeded 90% of its initial concentration at 25 degrees C was 1.2 days.
According to above, the degrdation is specific acid-base catalysed rather than general acid-base catalyzed.
However, there is contradiction with anothere reference:
2. The relationship of diastereomer hydrolysis kinetics to shelf-life predictions for cefuroxime axetil. Pharm Res. 1991 Jul;8(7):893-8.
Buffer catalysis was observed in acetate and phosphate buffers.
No significant kinetic effect was observed for ionic strength in the range mu = 0.1-1.0.
..........exhibiting maximal stability in the pH range 3.5 to 5.5.
3. Stability of cefuroxime sodium in some aqueous buffered solutions and intravenous admixtures.
J Clin Hosp Pharm. 1986 Feb;11(1):47-54.
Both buffered and unbuffered solutions followed first-order decomposition. In 5% dextrose and 0.9% sodium chloride injections, cefuroxime was stable for 1 day (more than 90% potent) at 25 degrees C and for at least 30 days at 5 degrees C. At -10 degrees C, there was negligible decomposition after 30 days. The pH values of the solutions stored at 5 degrees C and -10 degrees C remained in the maximum stability range and the solutions were clear even after 30 days of storage.
1. Since ionic strength have no effect, deionized water does nt have advantage. Buffered solution is advocated to maintain the pH (in maximum stability range, based on two studies pH range can be narrowed to 4-5.5). Buffer of species reported to not catalyzing the degradation.
2. 28 days storing of stock solution may be possible at low temperature (stability need to be established in hand). I will not prefer doing this and would change the practice and make fresh solution everytime.
3. Chances of finding information on stability in Methanol and Acetonitriles are remote (at least at first place).
