Tails in PCBs analysis
Posted: Fri Dec 16, 2005 11:51 am
I've a 5890 ECD for organochlorine pesticides and PCBs, with a DB-35ms column, all the peak has good shape except for PCBs which has a big tail.
The column is properly installed because all the other peaks are good.
But, after the analysis of dirty samples the shape of the PCBs are very good. But when I cut column and clean the injector the tails are again.
The injection is 2 µL in splitless mode.
Thank, Javier Camino
